Microsoft Wireless Display Adapter with Surface Pro 3 Resolution Problem
2015-01-23T23:46:25+00:00
My Surface Pro 3 is fully updated with the latest firmware and updates and the wireless display also has the latest updates.
When I have my bluetooth on and I connect to the wireless display adapter, my TV's max resolution that I can set is 1366 x 768 but when I turn my bluetooth off first and then connect to the wireless display adapter I can set my TV to 1920 x 1080.
It's kind of annoying to have to turn bluetooth off first before I connect to my tv. Is there something I can do to fix this issue?
Surface | Accessories | Wireless display adapter
    2015-01-29T10:37:53+00:00
    Nicolas,
    What exact BT devices are you using?
    In fact, i'm sure that it's the arc touch mouse which causes the problem, not all bluetooth devices. And this mouse is very useful when i'm doing powerpoint presentations (i'm a teacher).
    Nicolas,
    There are reports of this issue with phones connected via Bluetooth in this thread. Do you have a specific BT device that you can connect without this issue? It appears that if you connect a device AFTER negotiating the Miracast connection that the issue does not occur and the res stays at 1920 x 1080. Can you confirm this? Start the Miracast session with the mouse flattened and inactive and then wake the mouse.
    2015-01-29T11:03:20+00:00
    Nicolas,
    Nicolas,
    No, it's just the mouse. When it's connected, it's doesn't work at full HD. And when i reconnect the mouse, i encounter the same issue.
    2015-01-29T11:11:34+00:00
    I just did some testing with my Parrot Zik BT headphones - if they are active
    when I start a Miracast session, I indeed get the lowered screen resolution. If
    I start the Miracast session with these turned off, I get 1920 x 1080 and if I
    turn the Headphones on, I keep the higher res.
    I can repro with the Arc Touch Mouse Surface Edition as well.
    Barb
    2015-01-29T17:16:32+00:00
    Everyone,
    My contacts at Microsoft tell me that this is being investigated
    2015-01-29T19:41:05+00:00
    Same issue here. Dell u2410 monitor and MS Mobile Curved 6000 Bluetooth keyboard.
    Turning on Bluetooth will disconnect the wireless adapter. .
