have you tried reloading the wireless adapter driver for the Marvell WiFi in
device manager? What build of Windows are you using?
>>The wireless adapter has the latest firmware.
My Surface Pro 3 is fully updated with the latest firmware and updates and the wireless display also has the latest updates.
When I have my bluetooth on and I connect to the wireless display adapter, my TV's max resolution that I can set is 1366 x 768 but when I turn my bluetooth off first and then connect to the wireless display adapter I can set my TV to 1920 x 1080.
It's kind of annoying to have to turn bluetooth off first before I connect to my tv. Is there something I can do to fix this issue?
The adapter is a fairly useless bit of kit for a lot of people. Have a look at the previous messages in this thread as this is a fairly common (or variations thereof) issue.
