Micorosoft Surface RT won't connect to microsoft account or updat
2017-10-03T18:48:50+00:00
Hi there,
I have tried to sign into my Microsoft Account to connect the Surface RT, but every time it ends up with a message : "Sorry, we couldn't connect to Microsoft services right now. If this problem persists, search for "network problems" on the Start screen"
I have checked the clock, which is one of the culprits as per the forums, but i don't see any problem with it.
I have reset the surface to see if that would reset something but same result.
I have Run the WSReset.exe to same result.
I do not know what to do, without the Microsoft login, I can not do anything through the Microsoft Store.
Cheers,
Mohammad
Surface | Other
2017-10-04T08:10:15+00:00
Hi Mohammad,
We are aware that there are customers experiencing issues with Windows RT/8.1 devices connecting to their Microsoft accounts. Our engineers are currently working to resolve the issue as soon as possible.
In the meantime, please continue to use your local Windows login account for the time being. You may try to reattach your Microsoft account as a connected account at a later time.
We appreciate your understanding. Feel free to post back if you need further assistance.
Regards.
Mod Edit: Marking as answered to raise visibility.
(Update 10/11/17) A change was implemented on 10/10 that should resolve this issue.
67 additional answers
  1. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2017-09-20T10:53:00+00:00
  2. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2017-09-20T15:45:08+00:00
    I've just been told that "The Windows team has a bug on this and they are investigating.  They've been told how critical this is".
  3. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2017-09-20T15:46:36+00:00
  4. Barb Bowman 80,810 Reputation points MVP Volunteer Moderator
    2017-09-20T15:47:11+00:00
