Surface Pen or Multi-touch not working after Fall Creators update is installed on Surface Pro 4 or Surface Book
2017-10-20T17:33:35+00:00
After installing the new fall creator update, my surface pro 4 pen no longer writes, erases or interacts with the screen at all. All the buttons function normally. I used the Microsoft diagnostic trouble tree which had me replace batteries re-install the device, which did nothing. Is anyone else having this issue after the Fall Creator update installed, and if so do you have a solution? Thanks.
Surface | Accessories | Surface Pen
2017-12-08T02:31:30+00:00
Hi everyone,
Today, we released an update to the Intel® Precise Touch driver (Intel Corporation – HIDClass – 1.2.0.99). This driver resolves an issue where after Surface Pro 4 or Surface Book wakes from sleep, the touch driver will no longer respond to multi-touch input (like pinch to zoom) or the pen does not write.
You can find the details of the latest update on our Surface update history page.
Greg
260 additional answers
    2017-12-05T08:53:39+00:00
    Just received a device driver update. Listing itself in Windows Update was rather non-descript, but it did prompt a notification stating that a restart was required for the Intel Precision Touch device to function properly (or to work at all... hard to say as it was unexpected).
    Since the driver installed, and restarting, this issue seems to be resolved. Time will tell for sure, but things are looking up!
    2017-12-05T11:34:00+00:00
    Good news... for you
    Still 1.2.0**.83** here, as stated by Surface Update History, but hope to get it soon.
    May I ask :
    • What's your hardware ?
    • Are you insider ?
    Off topic: Anyone knows if updated Intel GPU driver is coming to SB v1 ? It is still in v20.19.15.4463 since July 2016 and not performing well since Creator Update...
    2017-12-06T05:12:37+00:00
    The first advice I always received for device issues was to ensure that I had the newest firmware and drivers from the manufacturer's website.
    In the case of the Microsoft Surface Pen, I found the following link which fixed the issue for me after I downloaded and installed 2 files on my surfacebook.
    I downloaded the surfacebook .msi file and ran it.
    I also downloaded the Wintab .zip file and ran the executable within it.
    Here is the link: https://docs.microsoft.com/en-us/surface/deploy-the-latest-firmware-and-drivers-for-surface-devices
    2017-12-06T21:14:12+00:00
    This seems to have worked for me! Thanks
    whoops spoke to soon. Came back after one evening. Started it up. Same problem. Darn.
