Surface Pen or Multi-touch not working after Fall Creators update is installed on Surface Pro 4 or Surface Book
2017-10-20T17:33:35+00:00
After installing the new fall creator update, my surface pro 4 pen no longer writes, erases or interacts with the screen at all. All the buttons function normally. I used the Microsoft diagnostic trouble tree which had me replace batteries re-install the device, which did nothing. Is anyone else having this issue after the Fall Creator update installed, and if so do you have a solution? Thanks.
Surface | Accessories | Surface Pen
2017-12-08T02:31:30+00:00
Hi everyone,
Today, we released an update to the Intel® Precise Touch driver (Intel Corporation – HIDClass – 1.2.0.99). This driver resolves an issue where after Surface Pro 4 or Surface Book wakes from sleep, the touch driver will no longer respond to multi-touch input (like pinch to zoom) or the pen does not write.
You can find the details of the latest update on our Surface update history page.
Greg
260 additional answers
    2017-10-21T11:11:11+00:00
    Hi Mark,
    Thank you very much. When I used the hardware and device troubleshooter it fixed the issue. It also fixed a problem with not being able to pinch to zoom. Thanks!
    2017-10-21T11:16:24+00:00
    Barb,
    I already went through resetting the surface. Going to troubleshooting device and hardware fixed the issue. Thanks
    2017-10-21T17:06:27+00:00
    i have the same problem also
    2017-10-22T02:38:29+00:00
    Hi Laura,
    To help you with your concern, we suggest that you follow the steps in the link provided by Mark.
    Let us know the outcome.
