Surface Pen or Multi-touch not working after Fall Creators update is installed on Surface Pro 4 or Surface Book
2017-10-20T17:33:35+00:00
After installing the new fall creator update, my surface pro 4 pen no longer writes, erases or interacts with the screen at all. All the buttons function normally. I used the Microsoft diagnostic trouble tree which had me replace batteries re-install the device, which did nothing. Is anyone else having this issue after the Fall Creator update installed, and if so do you have a solution? Thanks.
Surface | Accessories | Surface Pen
2017-12-08T02:31:30+00:00
Hi everyone,
Today, we released an update to the Intel® Precise Touch driver (Intel Corporation – HIDClass – 1.2.0.99). This driver resolves an issue where after Surface Pro 4 or Surface Book wakes from sleep, the touch driver will no longer respond to multi-touch input (like pinch to zoom) or the pen does not write.
You can find the details of the latest update on our Surface update history page.
Greg
260 additional answers
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-11-02T13:06:29+00:00
    there are lots of reports of this.
    Does pinch to zoom fail as well when in this condition? others have found that
    going into device manager and disabling/enabling the "Intel(R) Precise Touch
    Device" in device manager made both the pen and the multi-touch work again. Open
    device manager,  Click on human interface devices to expand it and it should be
    near the bottom of the list. This is a temporary fix and the issue may return,
    but for now, it is the only work around.
    2017-11-02T15:11:07+00:00
    Thank you. This was something that was bothering me a lot.
    I had to restart to get the pen to work. The buttons worked, but the tip was not responding.
    I disabled and enabled "intel precise touch" and it worked like a charm. thank you so much.
    Is there a way to fix it forever , or do i have to keep doing it.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2017-11-02T15:36:52+00:00
    For now, you may have to repeat this fix - hopefully Microsoft will issue a
    firmware/driver update to fix it permanently.
    2017-11-03T03:53:43+00:00
    Thank you, will try it and report back
