Surface 2 Speaker/Sound Problems
2013-10-23T17:22:07+00:00
I just purchased two new Surface 2's and I am noticing a significant reduction in volume from the speakers compared to my old Surface RT.  The speakers also lack any kind of bass.  They are very "tinny" and shallow sounding.  When using headphones, there is plenty of bass sound and the volume level is not an issue.
I am also experienceing a significant amount of sound crackling (from the speakers and attached headphones) when streaming video from Amazon Instant Video using both the desktop and metro versions of IE.  I do not experience this crackling problem with other sound sources like Xbox music, gaming, or other website streaming video (i.e. YouTube).
Since I was experiencing this on two different Surface 2's, it seems unlikely that this is a hardware issue.  This is most likely a software/driver issue.  Is there anything that I can do to resolve this problem, other than wait for a possible software or firmware update?
Thanks.
Surface | Other
    2013-11-25T01:56:02+00:00
    I tried watching a movie and with the volume at max I could barely hear it. I rolled back the driver from reading about it here and it seemed to fix it. I just hope they acknowledge this problem and are working on a permanent fix. Based on being able to restore my audio by rolling back the drivers should prove its not a hardware issue.
    2013-11-25T02:28:16+00:00
    I noticed that my sound was quieter than it normally is, even though I run at 100% so I tried rolling back the drivers, ended up losing sound so I updated to the latest driver again and still didn't have sound, but when I went to investigate it said that the enhancement was causing a problem and to turn it off, so I did and have sound, but still seems kind of quiet.
    I wonder if they stealth turned it off or something and that's why everyone is quiet all of a sudden...
    2013-11-25T03:18:37+00:00
    I would assume peeps are contacting Microsoft so they know the sound still sucks.
    2013-11-25T12:09:51+00:00
    So follow up on this this morning. I decided to try uninstalling all the audio codecs and the Tegra audio driver (deleting the driver checked). This left me with no sound and the driver could not be updated automatically. Manually however would work, but I had to use the 8/14 driver first, then the latest driver. This has restored my much louder sound, with the slight tinny-ness mostly in the higher ranges.
    I guess for those rolling back or uninstalling make sure to do the Tegra audio codec as well and this might restore things.
    The other odd thing I noticed was that the audio level would not go over 50% when I was forced to have enhancement turned off (little green bar in desktop audio control) which seems to line up with my 50% noise reduction. While not enhanced, there was no tinny-ness whatsoever which leads me to believe that this is a software issue rather than a hardware issue and hopefully the December 10th drivers will fix this.
    2013-11-25T12:22:16+00:00
    When you uninstalled everything, did you restart? Usually after the restart the new hardware is found and drivers are downloaded online? Did that happen? From where did you get the drivers for 8/14?
