Sound is great even when compared with my old Surface RT. The driver version for NVIDIA Tegra Audio is 9.17.13.2757 dated on the 23/10/2013
That's a newer driver so we don't have to worry about. Just wait.
I just purchased two new Surface 2's and I am noticing a significant reduction in volume from the speakers compared to my old Surface RT. The speakers also lack any kind of bass. They are very "tinny" and shallow sounding. When using headphones, there is plenty of bass sound and the volume level is not an issue.
I am also experienceing a significant amount of sound crackling (from the speakers and attached headphones) when streaming video from Amazon Instant Video using both the desktop and metro versions of IE. I do not experience this crackling problem with other sound sources like Xbox music, gaming, or other website streaming video (i.e. YouTube).
Since I was experiencing this on two different Surface 2's, it seems unlikely that this is a hardware issue. This is most likely a software/driver issue. Is there anything that I can do to resolve this problem, other than wait for a possible software or firmware update?
Thanks.
I downloaded that driver too, but its still the same...
Yeah same here. Already have this driver and no improvement.
I found that even when it said that was downloaded and installed, it was still using the old driver.
"Equalize Loudness" is not an available option in the surface 2 sound enhancements screen. I am almost sure my surface RT had equalize loudness. I am semi-convinced this is the issue.
