2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2016-07-26T09:12:21+00:00
    Hi all,
    My 2 cents. I'm having a similar issue of the System and System interrupts processes starting to take up to 25-30% of CPU of my Core i7 SP3 under Win 8.1. Please note my issue seems to happen mostly when the device is docked, to the extent that when the issue is noticeable, undocking often solves it. It did occur while undocked though.
    I ran through this thread and can confirm that my issue does seem to be related to the Realtek High Definition Audio device. The obvious way of proving this is to disable the Realtek device when the issue is happening, which results in an almost instant drop of both System and System interrupts CPU usage to 0%. Re-enabling the device brings those processes back up in some 10-20 seconds. (Which could be a simple proof for MS in case they were interested.)
    I'm planning to have disabling Realtek as a plan B for when it happens while undocked. I'm also thinking if it's possible to disable Realtek automatically when the device is docked, as the dock station has its own audio device.
    Hope this can be useful to some of you too.
    Best,
    George
    2017-01-24T07:53:39+00:00
    OMG  week 3 trying to figure this out.  You are a genius!!!!  How d you find this out?  My SP3 has been hot as the Sahara for awhile now....
