2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-09-10T22:41:49+00:00
    I'd like to add my own experience here to this list. I recently purchased a Surface Pro 3 which shipped with Windows 10 and have used it for several weeks without incident. Over this past weekend I received a number of peripherals that I'd ordered and installed them and when I returned to school on Tuesday I began to experience the problems that have been described here. The peripherals I installed were:
    SanDisk 128GB microSD card
    SanDisk 64GB thumb drive (not permanently connected, just for file portability)
    Vantec 10 port USB 3.0 hub
    Microsoft Natural Keyboard 4000
    Logitech G700s mouse
    IOGear USB 3.0 Ethernet adapter
    Pioneer USB 3.0 External BluRay Burner
    Previously I've been using a Vantec USB 2.0 external hard drive enclosure (forget what drive I put inside) and now I've got it connected through the 10 port hub as well.
    I tried the other suggestions I've found here and elsewhere and my findings were this:
    • Removing the microSD card didn't make a difference (though I didn't try restarting it with the card removed or deleting the drivers)
    • Deactivating Fast Boot and choosing shut down (not restart) and then turning it back on didn't make a difference
    • Turning on the microphone as described above and below DID fix the problem though with the associated 2-3% drain from the Windows Audio Device Graph Isolation process so I didn't keep using this solution.
    • Uninstalling the audio drivers as described elsewhere DID fix the problem though I haven't been through a full update cycle so I'm expecting the problem to recur after the next update.
    At this point my plan is to wait for another cycle of updates and see if the problem returns after that. If/when it does I'll probably spend a bit more time investigating the involvement of the SD card reader driver but having the SD card installed is pretty important to me (having expandable storage was one of the reasons I chose this device) so I don't know what I'll do if that ends up being the issue. I definitely get the feeling that the problem is a driver conflict with one of the devices in the list above. If anyone else's problems correlate to something on that list of peripherals I'd love to hear about it.
    2015-09-10T23:29:50+00:00
    After removing microSD, you have to restart at least once. Whatever is causing problem seem to be happening at kernel level, and fastboot saves kernel data in SSD. So, it won't take effect until restart.
    Also try restarting after disabling fastboot, then shutdown and turn on again. I don't remember which steps I took, but this may be worth a try.
