2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-03T02:00:13+00:00
    Hello OK_2,
    Do you have any updates for us? We look forward to further discussion with you.
    Please let us know.
    Best Wishes,
    Zack_T
    2014-08-03T02:19:39+00:00
    Thanks for getting back to me.
    I believe it started about 3 or 4 days after I got the SP3. Updates were installed through the PC Settings interface. Often, there were updates that were optional, but in my previous experience there were cases where the "optional" updates were in fact mandatory (like, it wouldn't update to Windows 8.1 without the "optional" update), so I just installed everything, including the optional ones.
    The only alteration I made to the power plan was to tell the SP3 never to sleep when plugged in. I also told the PC to not do "fast startup", in my attempts to force shutdown to behave like restart, but it didn't work oddly enough.
    While I have your attention, I may as well mention that occasionally, after waking up from sleep, the Wi-Fi connection is completely gone. Na-da. No network connection available, as if the wireless adapter was somehow unplugged from the device. Restart fixes this though. Still annoying. I believe this is a fairly well documented issue, as I've seen reporting of this on multiple websites.
