2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-08-31T20:38:32+00:00
    I still don't know why Microsoft haven't fixed this yet. It is obviously something related to the sound system and/or microphone combination. The microphone workaround really saves some battery life. But is not a solution, just a work aroundplease Microsoft...look at this issue. We already gave you a clue, so the hard part of what's causing it is provided to you.....is up to you to figure out if it is a software issue or a hardware issue and find a fix for it.
    Things that Microsoft next to fix to make us happy
    1. System, system interrupt issue with sound card-microphone.
    2) Wavy lines when writing slowly with the pen diagonal lines. (Still waiting on that "Pen Power" modification that Microsoft promised they were going to fix, how much from that have passed?, 6 month already??).
    1. I wish they fix the back side camera from fixed to auto focus....(Apple is replacing a bunch of defective cameras in their iphone 6 plus, because they look blurry....well this is almost the same thing we are experiencing with close up pictures....but Apple took the extra step and accept the flaw)
    Microsoft can design a complete new surface in a few month but cant fix these items in more than a year already.
    Fix those 3 things and make your customers happy.
    2015-09-03T22:16:36+00:00
    OK, so false alarm there - excessive CPU use seems to have come back after a few days.
