2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-08-31T00:21:42+00:00
    Hey folks.
    Here is the fix:
    Download and install the new Realtek sound driver from here. Its totally working.
    If link not working, go to thispage and accept the terms and download second  blue line 64bit Windows 7/8/8.1/10 drivers.
    2015-08-31T18:13:02+00:00
    The bad thing is that even after upgrade to Win10, I still facing this annoying issue.
    The good thing is, that the solution proposed by @Wildsoldier still working. It just disables your internal microphone, so things like Speech control or Cortana are wasted, unless you have external mic and I'm not sure whether the external mic will not cause the same trouble. But this has one good point, you can completely disable Cortana, since you cannot use it, and therefor became a little more spy-proof.
