2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-08-23T03:10:11+00:00
    Did you have microSD installed or some sort of USB device connected?
    If so, try removing them.
    If you didn't have any of those installed, may be it is different problem then what I'm having..
    I found there is another way to accomplish what you did with microphone while still allowing use of microphone.
    Under recording devices right click (or touch and hold) empty space.
    Check "Show Disabled Devices"
    You will see "Stereo Mix" which is disabled.
    Click Properties and and bottom under "Device usage", select "Use this device" to enable.
    Click "OK" and open properties again.
    From here, it is same as for microphone.
    Under levels, bring level down to 0 and/or mute.
    Under listen check "Listen to this device"
    Now you can undo settings done at microphone and use microphone as before.
    Doing this or microphone workaround will cause "Windows Audio Device Graph Isolation" process to use about 1 to 2 % of CPU all the time, but it still is better than 20% load from interrupts.
    2015-08-29T14:54:01+00:00
    Downloaded Build 10532. Fixed the issue for me. No longer have to be listening all the time. CPU mostly at 0% when idle.
