2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-07-01T17:54:33+00:00
    Surface pro 3 - i7 the large edition.
    The annoying interupts/cpu load only stops when I open the sound recorder from accessories as previously suggested by someone here!
    That's crazy and a real neglect of you guys at MS!
    We need a proper solution quickly!
    2015-07-01T20:04:42+00:00
    Tarzan,
    You don't need to open sound recorder in order to fix this. Did you tried my method posted in a few post back? My method do almost the same thing except that you don't need to open anything at start up.
