2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-23T22:14:14+00:00
    My method solves the issue of systems and systems interrupt consuming cpu resources....however if you leave your computer idle for a while...windows start doing doing some kind of process internally (microsoft may know better what the surface is doing...i believe is some kind of indexing) and makes the computer becomes hot....during this time the systems and systems interrupt may consume resources as well...however cpu usage shall return to single digits once you move the mouse or use the keyboard again and then you surface shall run cool again.
    I hope that Microsoft fix that Audio driver issue...but it haven't done it in about a year already so i believe its never going to get fixed.
    2015-06-26T14:52:57+00:00
    I have exactly the same issue with the fan going nuts when waking from sleep.
    I run into meetings and just open the keyboard from SP3 to continue working but this guy ...  fans is just nuts. It is not normal to keep "shutdown -r -t 0" all the time.
    I had the same issue with Surface Pro 2, got this SP3 now for more than $2k with 512BG, dock, VGA adapters and all the luxuries... to find out that this OLD problem is still not solved on a two generations old device ? Seriously.
    Besides this is BAAAD image overall, people watching me say MS and Surface are not there yet with delivering working horses and they turn back to their X1 Carbons. I'm tired of supporting "visions" without the other parties following through properly with promises.
    MS - this is purely your device, no TP components in it, keep it under control !! If not then ask other leaders how they do it then let go some people behind this product.
