2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-20T13:39:19+00:00
    As of yesterday back to square one :(
     Did you tried my method above? If you tried, did you check what process was taking a cpu hit? Does it was the systems and systems interrupt or other process?
    2015-05-23T21:51:48+00:00
    Thanks for this explanation, this has solved the problem with  the issue of systems and systems interrupt consuming cpu resources and my heat problem.
    Thank you very much :)
