2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-05-13T15:41:39+00:00
    I have just installed 2.77 from May 11, will keep you guys posted.
    SHAME ON MICROSOFT FOR NEGLECTING THIS ISSUE. I WILL ON EVERY POSSIBLE PLATFORM MENTION THEIR IGNORANCE AND ADVISE MY LESS TECH SAVY FRIENDS NOT TO BUY SURFACE.
    2015-05-13T19:01:45+00:00
    I just run Sound Recorder from Accessories and keep it permanently open and idle.  Works for me.  I avoid shutdowns and use hibernate instead to dont bother with recorder restarts.
    I agree:  SHAME ON MICROSOFT FOR NEGLECTING THIS ISSUE.
