2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-28T20:29:45+00:00
    Sadly this did not solve the problem for me: Provided temporary relief but problem returned.
    2015-03-30T02:58:55+00:00
    I have few surface pro 3 and i have noticed that even after clean shutdown. when i start the Surface pro again, my CPU up time show me it still running example. some times 20 days,
    How do i fix that please advise
    Thank you
    Miki
