2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-27T23:33:27+00:00
    All this to use the SD card slot.
    TLDR: One craptastic workaround thus far is to simply launch the SoundRecorder.  (execute soundrecorder.exe or run it from the start screen).
    Update: The problem has now returned and I'm still debugging it.  So what I've found so far is that this is actually being caused by an interrupt storm via the ACPI.sys (Power Management) driver from the realtek audio chipset.  Hence the audio driver looking like a possible solution before. So far my attempts to edit the acpi device config via the registry have been fruitless as the Realtek driver doesn't seem to respond to them at all. I did find that simply having the soundrecorder app open has a similar effect to playing sound.  When I launch it, the interrupt cpu% drops off immediately and remains there while the app is running.  Added to my startup and rebooted several times to see if it held and so far it is holding it at bay. Created a script to launch it as a hidden process but that causes other applications to lose focus sporadically, so that turned out not to be an admittedly slightly less craptastic option, but I tried :(
    Edit/NOTE: While you may find the below informative, it did not resolve my issue as it resurfaced the next day. Leaving this here in case you're hoping that finding an updated driver will fix it as the below driver probably won't help you.
    The same problem just befell me after adding in an sdxc card.  Tracked the problem down using sysinternals tools and livekd, definitely the audio driver sending interrupts at the cpu like an uncapped fire hydrant. Great now what, MS doesn't have a newer driver but Realtek does.  Version R2.75 of the 64bits Vista, Windows7, Windows8, Windows8.1 Driver. This package included version 6.0.1.7246 (2 months newer/minor build increment over Microsoft's). RelNotes didn't say anything outside of new driver customization options but gave it a shot anyway and it worked.  Popped open livekd and verified the barrage was gone.  Rolled back driver and it immediately came back.  Updated back to this version and problem was gone again.  Hopefully it stays that way.  If the link below doesn't work, just go to www.realtek.com's download page and drill down from the menu on the left to download the package described above:
    To drill down:
    Computer Peripheral ICs -> PC Audio Codecs -> High Definition Audio Codecs -> Software
    Direct link (that hopefully works for you :D)
    http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=14&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
  2. Deleted
