2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-16T14:13:59+00:00
    I can confirm that this problem is fixed by disabling Realtek audio driver in Device Manager > Sound, video... > Realtek High Definition Audio. I'm using external USB audio, so this is not major issue for me.
    Before disabling, the System & System Interrupts processes consumes around 30-40% of CPU, keeps the CPU at high clock, produces a lot of heat and therefors a lot of fan noise. After disabling the system idles at ~5%.
    Its ironic, that I bought Microsoft device because I assumed 100% hardware compatibility with Microsoft Windows. It's also ironic, that MIcrosoft, as a software giant, produce better hardware than softwar. Hope that Windows 10 will be more mature.
    UPDATE:
    Woaha. Disabling the Realtek audio driver seem to solve more than one problem. Previously, resuming from sleep sometimes do not woke up my external displays and I had to manually turn then on and off. Since I disabled Realtek audio, my external displays resumes from sleep every time.
    2015-03-21T19:16:01+00:00
    Rather than disable the High Definition Audio - I uninstalled the driver AND checked "Delete the driver software for this device." The default sound (High Definition Audio Device) driver will be installed (reboot or scan for hardware changes)."
    Result: Basic audio from the SP3 without the high CPU.
    REMEMBER this hardware device will prompt for Windows Update install. Will have to ignore that install (not sure if will install automatically if updates set that way on your machine) until the driver is fixed.
    Hope this helps.
