2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-12T12:08:58+00:00
    Can you email Susan at susan-at-msmvps.com (change the -at- to @).  You need you to give her a phone number so she can then set up a support case to have someone from Microsoft call you back. You will be able to submit the logs as well.
    2015-02-13T20:05:37+00:00
    I have been VERY happy with my Surface Pro 3 until recently.  I noticed it a couple of days ago but today it was markedly HOT when I went to use it this afternoon.  I wonder if this malfunction has been corrected in updated versions.  When it "goes to sleep" the backlight never goes off so i'm wondering if this has anything to do with this issue.  Today is was so hot i could not touch the screen.  it did not give a temperature warning was just very hot to the touch.
    Please let me know if i should return for a refund or if there is a fix for this issue.
    Thanks for your attention.
