2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-11T20:46:14+00:00
    Having spent the past two hours having a slow conversation via twitter with Surface Support I figured I share my issue.
    I've got an i7 SP3 256G fully patched up running no additional software.  Its in the same shape it was shipped in as I've not really adopted it full time due to the following issue.
    After booting up the system regularly shows a consistent CPU utilization of around 30%.  The 30 % percent is used by system and system interrupts.  After a few minutes the machine runs hot, the fans come on and the system feels sluggish.  Having read up on the issue it seems to have been around since the introduction of the SP2.  The issue only occurs when the machine is in its dock.
    Lots of people seem to attribute this to SD cards, usb peripherals etc, I've never used SD cards and it does it with no additional peripherals attached other than the cover / keyboard.  It does seem to be related to audio drivers as it can be stopped by playing audio or disabling the realtek audio device.  Normally it goes away after a reboot however today after plugging in external monitors even a reboot wouldn't shift it.
    I appreciate that there are a lot of different external factors that are probably causing this issue for different people hence the variety of community suggestions but they all seem to have one thing in common which is that everyone develops a work around.
    Has anyone had support from MS for the same issue?
    Alex
    2015-02-11T21:29:26+00:00
    Alex,
    I sent your post in to an internal contact. There will be some follow up. Stay tuned.
