2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-02-09T01:35:29+00:00
    I have had Thinkpads for many years and never had to worry that what I installed might affect their ability to sleep. Microsoft should be able to do as well or better!
    2015-02-11T17:05:58+00:00
    I am using a Pro 3 128G with i5, and have been having this problem just recently, probably for 3 weeks. Before that, the battery had been reasonably satisfied. But suddenly, starting from that day, the battery run out so fast during sleeping mode. It definitely drains overnight. So frustrating. I wouldn't have bought it if it turns out like this. Now, I have to turn the power off instead of putting it to sleep. If Microsoft doesn't solve this problem, it will surely lose its market.
