2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-19T16:54:15+00:00
    Well, I can say the latest firmware (installed 1/15/2015) and software updates (installed 1/19/2015) don't eliminate this problem.  If I ask Windows Update to check for updates, there are none -- "No updates are available."
    My System process CPU utilization just shot up (again) to 13% to 20%, and my System interrupts process is using 8% to 14%.  If I close everything and take my hand off the keyboard, my Surface's CPU utilization is 32% -- yup, my idle Surface Pro 3 CPU utilization is 32% ... and it's very (uncomfortably) warm in the upper right.
    This is soon after a cold boot in my docking station (1.5 hours ago).  So far I've replied to a few emails, responded to some Skype messages, and started working in VS 2013.  The fan is so loud I stop working to reboot so this problem goes away for a bit and my fan shuts up -- but chances are good I'll end up rebooting once or twice later today ... typical.
    I hate this thing ... dumped so much money into it (256GB SP3 with docking station).  It looks so stupid on my desk because I have this huge cooler underneath it to try and keep it running cool when System and System interrupts takes off.  When I'm done with taxes I'm going to see what I have left over, buy something else, and dump this.
    2015-01-20T22:34:36+00:00
    I have been having the same problem with the heat! And my battery seems to drain too.
