2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-01-11T12:57:23+00:00
    Thanks for your suggestion!
    After I restarted my Surface, the problem was gone. Perhaps this issue is going to start only after some time of usage?! I will try your fix when the high cpu usage returns!
    Imho MSI is an installer for the driver of a computer. Maybe this is fixing the bug in the soundcard driver?!
    2015-01-12T12:16:06+00:00
    It can happen when your device is running out of space. Windows needs at least 20 GB of free space in order not to have this System penalty.
