2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
  1. Deleted
    2015-01-06T12:17:12+00:00
    ich have the same issue as the others in this thread. If I turn off the music the process "system" in the task manager starts to use ~15% of the CPU load.
    I installed all latest updates. Please fix this bug, microsoft!
