2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-12-11T20:26:10+00:00
    I'm having this exact same issue with my brand new i7 256GB SP3. Battery drained while suspended overnight. The powercfg batteryreport shows this. Kinda frustrating...
    I'll try disabling wifi this time.
    2014-12-15T13:59:14+00:00
    I have the same problem.  Let me rephrase that, I've had numerous problems with the Surface Pro 3.  It is such a great device overall that I was willing to overlook some of the little things, but now some of the issues are counter-productive to the point where I might just have to give up on it if MS can't fix it.   My device is also the i7/256GB and my "USB hub" is a DisplayLink dock that I use to convert the SP3 into my main desktop computer.  Obviously, this won't work.  On top of the multiple OneDrive sync issues, the microSD card and some USB flash drives disconnecting during large file transfers (which I already had to warranty replace for), this is getting ridiculous!
