2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-22T22:31:33+00:00
    Hi jiachengguo,
    Thank you for your prompt reply!
    If you have reset the power settings back to default, if all background tasks and apps are turned off, if all accessories have been removed and if you have restarted your Surface, and the problem persists, we suggest your perform a Refresh/Reset.
    Below you will find the support article with details instructions on how to perform a Refresh:
    If after Refreshing your Surface the problem persists, we suggest you contact Technical Support by visiting our Self Service Center here or by contacting Support **here**.
    We hope this information is useful! Please keep us posted!
    We are always here to help!
    Best Wishes,
    2014-07-24T15:15:47+00:00
    Hi Chris,
    Thank you very much for reaching out to the Surface Community! I appreciate you taking the time to contact us to express your concerns. According to the picture, it does seem that System interrupts are taking up a lot of space - I will try my best to resolve the issue for you.
    • Do you have any accessories attached to the device, namely a Cover or a microSD card? Does it make a difference if they are all taken off?
    • I understand that the problems mostly occurs when waking from sleep. Is there a noticeable difference between waking up from sleep and turning on from a complete shut down?
    Let me know!
