2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-26T04:43:14+00:00
    Let's be clear: there is no background processes running that would justify such a fan usage as the CPU is nearly close to 2% at  all time when idle (did some regular checks);
    However  I can confirm that each time my SP3 (8GO/i5) is idle and hooked to power supply, the fan kicks for NO REASON. It stops right away when starting to use the machine. Again there is NO REASON for this behavior; so thanks to fix it.
    2014-09-26T15:03:01+00:00
    The issue being discussed in this thread is a little different. The System Interrupts process starts consume 10-20% of the CPU due to drive/hardware conflicts after letting the Surface sleep. I don't want to dismiss your particular issue as there may be further problems with the Surface's CPU management. However, I too have noticed significant CPU usage when "idle", but have not been concerned about it. Windows takes advantage of idle time to run various tasks such as indexing the file system for search, checking for, downloading, and applying updates, etc. At least in my case, when I returned to my Surface after letting it idle, any CPU usage and/or fan noise quickly stops once I resume work, indicating that it is indeed maintenance tasks that were just taking advantage of idle time. As I said, the issue in this thread is different. There's no good reason for the CPU usage and it doesn't stop when you're actively using the Surface.
