2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-25T12:35:31+00:00
    I'm having the already known problem of the "System Interrrupts" proccess consuming high CPU (20%) continuouslly after returning from sleep.
    I've read that some people relates this to the wifi drivers, so the first thing I've tried is disabling the wifi adapter (using device manager, disable). But the CPU remained high after doing this.
    So, I've tried unpluging my usb hub (I use it for connecting my keyboard and mouse, and sometimes to connect to Ethernet), and the CPU went down.
    I don't know if some of you are having the same problems. If so, maybe this post could help you. (Of course, I suppose MS will someday solve this too)
    pd. Just to be clear, the CPU went down after unplugin the usb hub. After one minute I pluged it again and the CPU remained down. So this is an aceptable workarround for me.
    luis
    2014-09-25T13:47:51+00:00
    This is a kind of weird behavior...i don't know if it's related to this topic or not but yesterday my surface pro 3 needed a little charge so I hook the surface to the docking station and start using it. It was weird that it was running cool when it was charging however I stop using it a few minutes before charging 100%...just leave it on the desktop mode. As soon as the battery was charged the fans on the surface began to run without adding any computing load to it. Looks to me that its a kind of setting on the surface that when running charged at 100% and is hooked up to the power cord windows tell the processor to increase speed or something.
