2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-07-18T17:11:35+00:00
       I notice my surface pro3 drain battery very fast (near 10% batter every hour). After already installed all the update for it, include the July 16th, I still see the battery drain very fast. last night, I put surface to pro to sleep and woke up in the morning the battery is complete drain. I have generate the sleep study report in the url
    https://onedrive.live.com/redir?resid=6EBAF58E1330C99A!931&authkey=!AFJl-dt2lFLNwp8&ithint=file%2c.html
    Any way to improve the battery ?
    2014-07-19T00:47:47+00:00
    Dear Clare,
