2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-06T20:23:10+00:00
    I have the same exact problem as OP.
    This is on i5 Surface Pro 3 with 256G drive.
    First time I noticed it was after cold boot, not after waking up from sleep. It had USB 3 flash drive connected at the time.
    Ejecting and removing flash drive fixed the problem immediately but this is obviously not an acceptable solution.
    All OS updates are installed. I have no Micro SD card in the tablet.
    Has Microsoft ever officially acknowledged this problem for Surface Pro 3? It has been an issue for Surface Pro 2 for over 6 months as just I found out this morning, reported by many people on this forum and others. At some point after that it seems that some update was issued that fixed it but I am not completely clear if it did because I found nothing official from Microsoft.
    The fact that the same issue is still present in SP 3 boggles my mind but fortunately for me I have a very simple solution for this - if real fix is not released within 2 weeks I will return my tablet as I am still within my return window.
    2014-09-15T15:33:32+00:00
    I've been over at the overheating forums for the surface pro 3, but I've narrowed it down to the same problem you all have been having.
    My system never gets too hot or overheats when doing normal tasks, heck even playing a game with medium settings with a small fan blowing in the back, the system only gets warm.
    But, when idle I have the same issues as you, my windows task host (taskhost.exe) or windows installer (tiworker.exe) kicks in taking up about 30 percent of my CPU each, and when this happens, the unit starts to heat up and the fan will start going.
    I dont know if this is just how windows 8.1 is and if that's the case, they need to fix the design because the tablet is overheating, but if not, then this is some kind of bad software issue. I've checked for viruses and malware already. I've done one system reset with the august updates installed at the time, and now I'm up to date with all software updates.
    Can someone verify if this is just normal behavior for Windows 8.1 and thus the surface pro with i7's are not designed for the thin tablet form or if this is some kind of bad dll or software issue.
