2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-06T04:17:16+00:00
    I have an SP3 i7 256GB.  I put it to sleep at the end of the day (5pm), unplugged it (fully charged) and bought it home.  At home I took it out of the bag, confirmed it was a sleep, but noticed it was slightly warm in that upper right corner.  I used it for ~2 minutes to check urban spoon and then closed it (to sleep) while I took the family to dinner.  At 9pm I noticed it was still warm but indeed still asleep, when I opened it up.  The battery is down to 60%.  I double checked that the settings say it's supposed to go to sleep and the screen was at least off every time I checked it.
    This is VERY frustrating.  I recognize that there's a lot of RAM being used ~4GB but Windows doesn't want me to control this.  I do have one file open with PPT, but my 6-year-old Dell M1330 has no trouble keeping it's 4GB charged for long periods of time.  Also, there was at least a 3-hour stint where the SP3 should have gone into a deeper hibernation, right?
    Is this a common problem?  Thanks for your help! (FYI, I'm up to date on my Windows Updates, and I haven't played around with the power settings at all.)
    2014-09-06T05:16:54+00:00
    Looking a little closer, at the processes taking up the CPU, I see that essentially "System" and "System Interrupts" are constantly taking up an average of 20% of the processor (swings from 10-30%).  I feel like I've read about these processes being a problem on the SP3.  What are people doing? More importantly, what is MS doing about this? Could it be doing this while it's supposed to be asleep?
    I'll now add that I tried shutting down and then restarting, but it went right back to the 20% usage by the same two processes.  I then went into airplane mode and the processes WENT AWAY!!  I switched Airplane mode off and it stayed at 0-1% idle.  Ugh WiFi... I guess MS is about to send out another patch?
