2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-26T22:12:32+00:00
    I am having the same issues with my Surface Pro 3.
    I get anywhere from 20%-50% CPU on idle, the two biggest culprits being System and System Interrupts.
    What's interesting is that if I run a fullscreen game and then exit back to desktop, my system goes back down to 1%-5% idle. Maybe starting up the game kills something in the background? I am not sure.
    I am running the i5 128gb model.
    2014-08-26T22:53:21+00:00
    I think your games audio is stopping the idle issues, which is why I think its driver related to the audio driver.
    Run this simple test, when you have high idle CPU load - Play an MP3 or any music file and you will see the CPU drop to 1-3%
    Microsoft: Can we plesae have an update on this? It still present and I still have horrible battery life from this issue.
    I went from 100% to 90% in around 20 minutes...
