2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-08-09T02:17:32+00:00
    Sorry for the late response. Been busy.
    Unfortunately, neither refreshing the PC nor returning the power plan back worked. All updates have been installed.
    2014-08-10T00:21:55+00:00
    Hello ChrisG\_NZ
    Can we get the specifics of the MicroSD card you are using?  Doing a little investigation here.
    Best regards
