2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-02T15:17:49+00:00
    I'm also experiencing this issue. I have a Surface Pro 3 i7 256GB with 8GB of RAM. The problem is easily reproducible.
    1. Put device to sleep. Any way you like.
    2. Wake device from sleep. Any way you like.
    3. Watch CPU burn at constant 30-40% between "System" and "System Interrupts".
    4. Play an audio file. Any audio file.
    5. Watch CPU go down to normal 0-5%.
    6. Stop playing audio file.
    7. Watch CPU go back up to 30-40%.
    8. Repeat steps 4-7 at will seeing exact same result.
    9. Restart Windows to solve the issue until next sleep.
    2014-08-29T08:50:04+00:00
    I can't confirm this, when I open an mp3 File System Load is still the same ...
    Surface 3, i5, 256GB
