2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2014-09-23T17:10:19+00:00
    Hello all
    Please keep in mind that processor use under normal conditions will fluctuate, sometimes due to background processes.  This will not impact performance when you are using Surface.
    Best regards
    Sorry, but I find this a bit disingenuous. One of the few official Microsoft replies to this issue that has plagued the Surface for two generations now, and all we get is "processor use under normal conditions will fluctuate". Yes, we are all aware of that fact. If that's all it was, I for one, wouldn't be here, and I'm sure the same applies to the others in this thread. There is a real, reproducible problem, that causes the CPU to operate in excess of normal operating conditions. It's not some background task doing something, but rather the system fielding an endless barrage of system interrupts, clearly indicating hardware/driver conflicts. Please, provide real support to your customers and not such useless platitudes.
    2014-09-23T15:41:35+00:00
    Hello all
    Best regards
