2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-03-27T01:21:57+00:00
    Hello!
    The fan on my Surface Pro 3 will randomly start running very hard and the back of the screen will heat up considerably when nothing is running or when I'm simply browsing in Firefox.
    When I launch Task Manager to see why it's running so hard, it will show up that my CPU is maxed out with 90-100% being used. Then within seconds, the percentage drops down to 5%. This happens every time the computer is running hard and I go to see what background program is responsible.
    Can anyone explain how to fix this?
    2015-03-24T16:20:23+00:00
    Don't put any pdf files on Onedrive, or uncheck the PDF extension checkbox in the Advanced window of Indexing Options.
    -M
    This is a known, but separate issue. To fix the problem with the Windows indexing service causing high CPU usage due to PDF files, you can download Adobe's 64-bit PDF iFilter driver from here:
    Adobe PDF iFilter 64 11.0.01
