2014-07-22T12:13:28+00:00
2014-07-19T23:25:46+00:00
Hi jiachengguo,
  2. Select Settings
  3. Select Control Panel
  4. Select Power options
  7. Select Yes
  8. Restart your Surface
We are here to help!
Best Wishes,
2014-07-19T17:43:11+00:00
2014-07-19T02:11:55+00:00
Dear Clare,
198 additional answers
    2015-04-14T14:16:22+00:00
    So, I have the same problem with my Surface Pro 3, I7, 256GB.
    Processe System Interrupts are using about 8-9% of processor usage.
    In idle situation, my machine is using around 25% total CPU ...... it's insane.
    If I disable the Realtek audio driver it seem to solve my problem.
    My CPU returns to 2-4% of total CPU usage.
    So, cleary it's related with Realtek Audio driver,
    Microsoft please solve this probelm.
    Thanks!
    2015-04-11T04:01:05+00:00
    Sleep mode is a reduced power consumption mode that turns off the user interface while the rest of the device "sleeps".
    When "asleep" a Windows 8 / 8.1 tablet will still poll WiFi connections and do some background processes.
    My Surface Pro 2 seems to have daily updates. It quickly empties my data download quota on a 3G connection (via WiFi router). Had to change the Settings to prevent it downloading updates when on 3G.
    The only way to stop my Surface Pro 2 from doing anything is to Shut down when not needed and is being carried. I only use Sleep when it is connected to the mains power and is sitting on a desk.
    Shut down with a Surface Pro is similar to the old Hibernate on earlier versions of Windows in that it saves current configurations to a file so that it rapid boots when switch back on. It is very quick to boot up from a Shut down state.
    So: Do not use Sleep when the Surface is bagged and being carried. Use Shut down instead.
    In a way, it is by design; it is not a defect.
    Should also note that before the Surface Pro 2, I owned an ASUS Smart Tab tablet that I upgraded from Windows 8 to 8.1. It showed the same battery drain on sleep that the Surface has. It would go flat in about 3 days if left to sleep alone.
