Surface Pro 9 lagging after sleep but only until power supply is conected
2024-02-08T07:57:04+00:00
I have a MS Surface Pro 9 and after waking up from sleep the screen is always sluggish (i.e. the mouse moves aren't fluid). However, as soon as I plug the power supply the lag goes away and is away even when I unplug it.
I've done a diagnostics but couldn't find anything.
Any ideas what could be the root of this problem? I don't have anything ressources intensive that is running.
ioan
2024-03-19T19:16:03+00:00
Updated April 26, 2024
Thank you for reporting the issue. A fix is now available through Windows Update. For more information about updates for your Surface device, please see Surface Pro 9 update history.
62 additional answers
    2024-05-08T18:38:41+00:00
    I still have this exact issue even after the update - I checked Windows and app updates before posting, and there are no updates waiting, including optional ones or app store updates. Any other ideas?
    2024-05-21T16:28:08+00:00
    Hey Loan,
    If users are still struggling a redditior found a solution.
    https://answers-afd.microsoft.com/static/images/image-not-found.jpgQuote from "Select_Window_3115"
    "This also happened to me when I bought the surface pro 9, and this is how I fixed it permanently. Download intel graphics command center from Microsoft Store, and navigate to "System", then navigate to "Power" and turn off "Panel Self Refresh"."
