Surface Pro 4 Pen needs to be re-bluetooth paired after waking up/turning on surface
2016-10-26T22:13:22+00:00
My surface pro 4 pen needs to be re-paired via bluetooth after the computer has been sleeping/hibernating in order for the eraser button to function when clicked.  It still shows up as a connected device in the bluetooth settings, and still writes properly even when the eraser button does not work.  After removing the pen from the list of connected devices and re-pairing, everything seems to work properly but this is obviously inconvenient. Thanks for any help you can offer!
Surface | Accessories | Surface Pen
    2016-12-11T00:16:03+00:00
    I've got the same issue as well.
    When I repair it it works. But when I turn BlueTooth off and on again the pen dpnes't work it doesn't open OneNote or take screenshots.
    It is a bit annyoying
    2016-12-14T21:05:01+00:00
    Got this. We have forwarded this issue to the designated team for review. You'll be informed as soon as we have an update on this.
    Regards.
    2016-12-16T01:54:38+00:00
    Thank you very much. What is the minimum waiting time for this?
    2016-12-16T22:05:24+00:00
    Just to add: I'm experiencing the exact same issue with a brand new Surface Pro 4. After waking the device from sleep I have to re-pair the pen via bluetooth, otherwise the buttons don't work. All the drivers and Windows are up-to-date. No troubleshooting steps helped.
    2016-12-18T15:25:14+00:00
    Has there been any update to this?? I'm experiencing this to. My Pen doesn't appear to work (even though shows connected) but then eventually starts working later. Its really annoying.
