Thank You
Surface Pro 4 Pen needs to be re-bluetooth paired after waking up/turning on surface
My surface pro 4 pen needs to be re-paired via bluetooth after the computer has been sleeping/hibernating in order for the eraser button to function when clicked. It still shows up as a connected device in the bluetooth settings, and still writes properly even when the eraser button does not work. After removing the pen from the list of connected devices and re-pairing, everything seems to work properly but this is obviously inconvenient. Thanks for any help you can offer!
Surface | Accessories | Surface Pen
2017-04-10T10:03:32+00:00 -
2017-05-30T00:35:20+00:00 The creators update did NOT fix bluetooth connection problems with my pen reconnecting after sleep.. Did it work for anyone else?
2017-05-31T15:18:37+00:00 Take this reply with a pinch of salt.
At the moment (and for the test I made), I found a solution launching the (Control Panel) -> Troubleshoot -> (under Find and Fix other problems) -> Hardware and Devices.
Windows has found some problems and has fixed it.
From that moment on, the pen has not given me any more trouble and it seems to work even after long standby times, and even if I turn off and on again the bluetooth voluntarily.
2017-06-13T11:26:59+00:00 I have this problem too. I installed the Windows 10 Creators Update and it does not work.
But after installing the Creators Update I have uninstalled the Radio Card from Device Manager (right click on Radio Card > Uninstall) and rebooted Surface (Pro 4).
In the boot fase he tells me he's updating.
After the "update" the Pen works.
I hope this solution may be useful for you. Thanks.
