Surface Pro 4 Pen needs to be re-bluetooth paired after waking up/turning on surface
2016-10-26T22:13:22+00:00
My surface pro 4 pen needs to be re-paired via bluetooth after the computer has been sleeping/hibernating in order for the eraser button to function when clicked.  It still shows up as a connected device in the bluetooth settings, and still writes properly even when the eraser button does not work.  After removing the pen from the list of connected devices and re-pairing, everything seems to work properly but this is obviously inconvenient. Thanks for any help you can offer!
Surface | Accessories | Surface Pen
    2017-04-03T09:19:44+00:00
    Globally. And yes, April 11 for everywhere and April 5 for those that want to manually upgrade.
    2017-04-03T09:36:30+00:00
    Will the creators update be as any normal update?
    2017-04-03T10:42:48+00:00
    it will take longer - and there will be multiple restarts. plan on anywhere from 45 minutes to 2 hours. it will take a while to download..
    2017-04-04T12:29:47+00:00
    so do we just wait with aggravation in the meantimeor can those with the problem get an earlier fix
    2017-04-04T12:38:34+00:00
    You will be able to download the Creator's Update tomorrow, April 5th.
