AUTOROTATE ON - Randomly pops up...
2015-11-14T15:49:04+00:00
I am sure it is another display driver bug with, but please fix it. Whether it is Edge or the display driver, please fix it.
Surface | Surface Book | Display and screen
    2015-11-16T14:55:15+00:00
    Hello photobriangray
    Thanks for reaching out to us.
    Can you explain what it is you are experiencing with your Surface Book?
    Best regards
    2015-11-17T00:30:37+00:00
    I am having the same thing but it only happens up to 3 times when I either power on my Surface Book or wake it from Hibernation.
    2015-11-19T16:42:16+00:00
    Hello MichaelJKenny
    Detach the Clipboard from the Keyboard
    Clean the five connectors on the keyboard with a lint free cloth and isopropyl alcohol
    Reattach the Clipboard
    Best regards
    2015-11-19T20:20:06+00:00
    The Auto-Rotate notification pop-up in the upper left randomly shows up, though most often upon resume. This is with the keyboard attached.
    2015-11-19T20:41:09+00:00
    I'm seeing this too. Even when driving external monitors. Seems like there may still be a lingering bug with the tablet mode / regular mode switch detection making the device think it's no longer connected to the keyboard base, and hence re-enabling the auto-rotate mode (which displays its notification in the upper left).
