Surface Dock 2 Display Problem
2020-06-05T14:16:32+00:00
Dear Microsoft-Team,
Dear Community,
I recently got the brand-new Surface Dock 2 for my home office. I try connecting it with my Surface Pro 7 and a Samsung C34J791 (LC34J791WTUXEN) monitor with the supplies USB-C cable from Samsung which came with the monitor.
Windows is recognising the monitor fine, it shows up in the screen settings.
But the display is not showing any images, it just keeps switching through the inputs to find a proper signal and after some time the monitor goes into sleep mode as it could not find a signal.
If I now connect the display to the Surface Pro 7 directly with the same cable it works just fine and I can see the desktop on the Samsung monitor.
What do you suggest?
Thanks a lot in advance for your kind assistance and have a great weekend!
Best regards,
Julian
    2020-11-12T14:36:49+00:00
    Hello
    I recently upgraded from my SP3 to SP7 so I come into this a pretty big fan.  I had some of the same problems connecting my SP7 to external monitors through DS2.  For the most part, that was remedied by some rather expensive USB-C to HDMI cables.  I can disconnect and reconnect seamlessly.  However, I remain disappointed with external monitor resolution.  Below are two screen shots that illustrate the issue.  The monitor is an ASUS VG245H.  Maybe I am doing something wrong.  I am disappointed to take a step down in external monitor resolution on a $2K computer upgrade.  Sincerely
    2020-11-20T04:20:18+00:00
    I'm stuck working from home and my employer provided a Surface Pro 6 to connect with the office. I do a lot of spread sheet work and need two full size monitors.
    I have connected a brand new Dock 2 to my Surface. The Dock 2 is connected via USB C to HDMI cables to two external Dell U2410 monitors. The Dell Monitors flicker on and off constantly when connected to the Dock 2. Both monitors are detected properly in the settings but just wont work using the Dock 2.
    When I connect the monitors (one at a time) to the Pro 6 using the Display port to HDMI cable both monitors work flawlessly.
    I think the problem are the USB C to HDMI cables (using new CableCreations USB C to HDMI cables 4K@30Hz). Can anyone recommend a good USB C to HDMI cable?
    BTW - I'm extremely disappointed in this product - $300 and it doesn't work.
    2020-11-20T04:51:24+00:00
    Hi All,
    I found a solution to this - but be prepared to open your wallets - again....
    So after purchasing a $3000 Surface Laptop 3, $400 on a Surface Dock 2 and 2 x $30 on USB-C to HDMI Cables, I could not get the dock to work.
    The cables work when connected to the USB C port on the laptop directly to the monitor, but not via the Dock 2.
    After many hours on the phone with MS Support, I finally took the plunge and purchased 2 x Belkin USB C to HDMI adaptors (over $60 a pop) and 2 HDMI cables. Surprise, surprise it worked!
    The only reasoning I can come to is that the USB-C to HDMI Cable did not support 4k @ 60Htz, which the adaptors resolved. I had a look around, and I can't find a direct USB-C to HDMI cable that supports 4k @ 60 (only 4k @ 30).
    Hope this helps everyone out.
    P.S. I do think it's pathetic that we pay a MS premium for a MS Dock 2 and then need to buy more peripherals to make it work. What a costly exercise - next laptop, I'll be going back to a Dell, HP or Lenovo, etc.
    2020-11-21T03:05:27+00:00
    Thanks aditools - I purchased two Belkin USB C to HDMI adapters (4K@60Htz / model #F2CU038btBLK) and two HDMI cables (M/M / Insignia Model #NS-PG09501-C) and the dual Dell U2410 external monitors now work perfectly! The fix cost an additional $200.
    FYI - be prepared to potentially pay +$300 for the Dock 2 plus an additional $200K for HDMI adapters and HDMI cables to connect two HDMI monitors to a Surface Pro 6.
    Everything else on the dock actually works very well and the single point connection to the surface is a good design to leave your desk less cluttered.
    2020-11-30T15:03:54+00:00
    i had the same problem as more or less all decribed. Bought a dock 2 and had no output to monitor.
    All worked fine directly on my surface pro 7, but not via the dock.
    thought the best and fastest solution was to call mirosoft support here in dk and spend 2 hours on the phone with no solution.
    Ended up thinking that my display was to old for the dock and decided to by a new display. But...same problem.
    Finally i just wrote "surface dock 2 problem" in my browser, got in here and could see that the adapter from microsoft was needed, ordered it and all is now good.
    I just wish, and believe it´s fair to expect, that microsoft support had told that when i called then i would have saved myself from buying a usb-c to hdmi cable and a new monitor.
    i actually think it would be reasonable that microsoft informed about this when i ordered my dock 2.
    Having had a surface pro 3 for years with a dock that just worked, i find this very dissapointing.
    Andy
