No data connection for both WiFi and mobile data (sim) on Surface Duo 2
2022-08-19T09:33:21+00:00
Overnight lost data connection for both WiFi and mobile network.
Restart phone - didn't work
Reset WiFi/mobile/Bluetooth settings - didn't work
Factory reset - didn't work
Sim is working fine in another mobile device
WiFi working fine with other connected devices at home
I can make and receive calls using Sim, but it shows an "x" on the network icon. No mobile data
I can see the WiFi network around me, but when connected it'll say "limited connectivity"
What should I do?
Surface | Surface Duo | Network
    2022-08-23T19:05:30+00:00
    Hi Nur SaheranAbdul Hamid,
    Since you have already performed a factory reset and it did not resolve your issue, the next step would be a replacement.
    Here’s how to request a repair or replacement for your device.
    Note: Your device must be registered under your Microsoft account to submit a repair request.
    1. Go to Device Services and sign in with your Microsoft account.
    2. Select the device you want to submit a service request on.
    3. Click 'Info & Support
    4. Select Start a Service Order and follow the instructions to complete the submission process.
