Keyboard stopped working on Surface pro 8. Why?
2023-03-12T21:37:29+00:00
So I take my surface pro 8 and the keyboard doesnt work or charge the pen, though it did an hour ago. I tried going to uefi but the keyboard still work. I updated it and it still wont work. My microsoft virtual keyboard also stopped popping up when I click on typable fields, so i had to go to settings and change it from "when keyboard is disconnected" to "always" to be able tp type anything.
2023-03-13T16:05:13+00:00
Hi AaronKilo,
Thank you for reaching Microsoft Community. We're sorry to hear that the keyboard on your Surface device stopped working.
There could be several reasons why your Surface Pro 8 keyboard is not working, the keyboard may not be properly connected to the Surface Pro 8. Or Outdated or Faulty Drivers: The drivers for the keyboard might be outdated or faulty. Here are some troubleshooting steps you can try:
Detach the Type Cover or Keyboard
  1. Unplug your Surface and detach the Cover.
  2. Make sure there's no debris, damage or anything that may inhibit a connection.
Force your Surface to restart
  1. Select Start> Power> Shut downand wait for your Surface to shut down.
  2. Now, press and hold the power button for 20 seconds. If you see the logo screen appear after a few seconds, continue to hold for the full 20 seconds until you see it again.
Reattach the Type Cover or Keyboard
  • Re-attach the Cover, making sure that all the magnets touch the bottom edge of your Surface.
Confirm functionality
  1. To confirm connectivity, press the Caps and Fn keys on your Surface Type Cover or Keyboard a couple of times to check whether the LED lights turn on and off.
  2. If the LED lights don't turn on, there might be a hardware issue and the next option is tosubmit a service order.
  3. IF the LED lights turn on, please see Troubleshoot Surface Type Cover or Keyboard - Microsoft Support for more troubleshooting steps.
Let us know how it goes.
Kind regards,
Lavenia
50 additional answers
    2023-11-30T19:58:13+00:00
    I have the same issue that also started recently and it is absolutely a software issue. However, I have found a temporary workaround.
    If you boot into UEFI mode first (hold volume up button while powering up) and then restart the surface keyboard will work in Windows. However, shutting off the Surface and booting/rebooting Windows normally results in the same behavior (keyboard not working). Hopefully, Microsoft can get a patch out soon but this should at least make the keyboard functional in the meantime.
    2023-12-01T20:27:18+00:00
    Me too... have contacted support who've told me to buy a new keyboard. Seeing as though there are others with the same issue I'm not convinced it's hardware, but I've ordered one anyway to tell. Unfortunately 17 days of out warranty! Still, doesn't seem right that a £160 keyboard should only last two years. Will update when my new one comes.
    Seems the signature keyboard introduced with the Pro X (and used by Pro 8 and 9 as well) has some longevity issues. I got my first one in December 2019, and had to replace it under warranty within the year. The 2nd one died a bit more than a year later. I think now I'm actually fighting the keyboard connect port as the 3rd signature keyboard has gotten finicky, and a non-signature keyboard does the same thing (the one without the pen )... I suspect those tiny pins don't hold up well either.
    Compared to the Surface RT... got a first gen + type keyboard and it worked flawlessly up through the end of 2019 when I finally replaced it. I love the thin design of the new models, but the keyboards have been a downgrade from my own experience. Hence I'm not surprised when I see threads about Pro 8/9 having keyboard issues unfortunately.
    All I can say is good luck y'all. Maybe you'll luck out and it really is a windows update or firmware update.
    2023-12-01T20:53:11+00:00
    Hello.
    So I got my new Type Cover today, and I'm afraid to say... it works. Therefore the previous one broke. After 747 days of pretty light usage to be honest, it's quite disappointing. As you say, the old ones were much more durable. I had original Surface Pro, and SP5 for 4 years each and no problems at all with the keyboard.
    At least this new one comes with 2 year warranty, so it'll get me to whatever I buy next. If that's Surface Pro again, I really hope they change the design!
    I love the Surface stuff, but I had to give up with the Headphones too, had both the first and second versions which both disintegrated within a few months. No wonder Panos jumped ship!
    2023-12-02T04:01:43+00:00
    I am having the same problem.
