This website helped me A LOT and it fixed the brightness issue. Yayyy!!!! Seriously though, try it. It worked!!!!
Surface pro 3 Brightness control missing
Again the same old issue. After the last windows update (version 1903 build 18362. 239) i cant adjust the screen brightness ( is set in 100% and it is draining the battery).
This is the second time an Windows actualization creates this issue.
Does anyone have a clue how to fix it this time?
Thank you
Paulo Souza
2020-09-26T03:40:07+00:00 -
2020-10-21T01:11:07+00:00 Cannot move the slider. I'm having the exact same problem. Have removed and updated drivers multiple times.
2020-10-21T01:30:04+00:00 This is total horse hockey Microsoft. It's clearly a bug that many are experiencing. Now on Windows 10 Pro 2004 and it still does not work.
I won't be buying another Microsoft device again.
