Surface Dock Firmware Updater won't install - Failed to install SurfaceBaseFwUpdateDriver.dll
2018-02-02T13:12:27+00:00
Hi
I'm trying to install a firmware update for the Surface Dock I am using connected to my (first generation) Surface Book.
Primarily I'm trying to do this so I can charge my iPhone from the Surface Dock without having the connection repeatedly connect and drop.
I am running Windows 10 (Creator's edition, up to date as of 2nd Feb 2018) and trying to install:
Surface_Dock_Updater_v2.12.136.0.msi
During the installation process I get the following message.
Failed to install SurfaceBaseFwUpdateDriver.dll. Aborting installation.
Any ideas?
Regards
Jonathan
    2018-03-05T11:50:21+00:00
    Hi Claus,
    If you have issues with an external display connected to Surface Dock, try to clear the display cache.
    1. Undock your Surface from the Surface Dock.
    2. Download the Surface Dock registry file. Choose to Open the file.
    3. Select and run surface dock registry.reg.
    4. Select Yes to allow changes to your Surface, select Yes to confirm, and then select OK to close.
    5. Restart your Surface, reconnect it to the Surface Dock, and try your external display again.
    Reset the dock and monitor
    • Remove the Surface Connector from your Surface, turn the connector over, and plug it in again. Make sure that the connection is secure and the indicator light is on.
    • If you’re still having problems, try resetting the power by unplugging your Surface Dock from the power outlet and plugging it in again.
    • Try unplugging your monitor from the power outlet and plugging it back in.
    Let us know if you need further assistance.
    2018-03-27T22:50:20+00:00
    I am having the same problem on first gen SurfaceBook
    2018-03-28T10:38:01+00:00
    Hi stsmith70,
    Your issue may be similar to the other posts on this thread. I suggest you go through the previous suggestions to work on this.
    Let me know if you need more help.
    2018-03-28T14:23:19+00:00
    I have done the suggestions and they don't work
    2018-03-30T00:09:05+00:00
    Some Community members tried to unplug and replug the power adapter side of the Surface Dock, then tried to ran the Surface Dock Updater again. Also, try to uninstall the other update package then try to run the update again.
    Let us know if you need more help.
